Water Overlay
(Redirected from Water Overlays)
Variants
A Water Module will be initialized by adding one of the following Overlays to a project. Each variant has a number of parameters tuned to best fit specific use-cases. This means that each of these overlays is based on the same theory and calculation method, however they are customized to conveniently provide insight in different aspects of the Water Module.
Results
With a Water Overlay, a user can generate multiple results for a single water simulation. For further information about these outcomes, see also results and result types.
Features and components
