Weir target level (Water Overlay)
  • The interval before re-evaluating the Weir height is configured using the Water Overlay's model attribute WEIR_MOVE_INTERVAL_S.
  • This value is set as a single value, not an array.
  • The weir can move with a distance defined in the overlay with the model attribute WEIR_MOVE_STEP_M.
  • The weir's movement range can be set using the overlay's model attribute WEIR_MOVE_RANGE_M. This can be interpreted as the maximum allowed difference in the configured WEIR_HEIGHT (at that time) and the adjusted weir height.
  • A value of -10000 means the weir target value is non-functional. In such case, the weir height at time t is used.
