Result types (Heat Overlay)
The DPRA Heat Module of the Heat Overlay performs complex calculations and can generate multiple types of results per timeframe. A timeframe in the Heat Overlay corresponds to a date and time for which a result will be calculated. This date and time will be relative to the project's time zone.
List of Result Types
BOWEN RATIO | ratio | Date-Time | The Bowen ratio of buildings and terrains. Is used to describe the type of heat transfer for a surface that has moisture. |
FOLIAGE | fraction | Start | The initial and optional calculated foliage height, depending on the source of the foliage height. |
PET | °C | Date-Time | The calculated physiological equivalent temperature. |
PET_RELATIVE | °C | Date-Time | The calculated physiological equivalent temperature, relative to the calculated atmospheric temperature. |
SHADE | boolean | Date-Time | Indicates whether a cell is in the shade or not based on sun ray calculations. |
SKY_VIEW | fraction | Start | The calculated sky view factor. |
SKY_VIEW_AVG | fraction | Start | The calculated average of individual calculated sky view factors. |
TEMPERATURE_ATMOSPHERE | °C | Date-Time | The calculated atmospheric temperature, based on the calculated urban heat island, sun motion factor and the measured temperature. |
UHI | °C | Date-Time | The calculated urban heat island effect. |
VEGETATION | fraction | Date-Time | The fraction of vegetation per square meter. |
VEGETATION_AVG | fraction | Date-Time | The calculated average vegetation based on the cells' individual vegetation fraction. |
WIND_SPEED | m/s | Date-Time | The wind speed calculated for the height of 1.2 meters above ground. |
Result types can differ in the kind of data they display and in what way that data is recorded. A result type can be monitoring the data in one of the following ways:
- Start: The data is determined at the start of the simulation, and does not change over the course of multiple time steps.
- Date-Time: The data is dependent on the timestep, which corresponds to a date and time.
