How to remove areas with a filter
Editor → Current Situation (Ribbon tab) → Areas (Ribbon bar)
To remove multiple areas which share the same attribute:
How to remove multiple areas with a filter:
  1. Select "Areas" in the ribbon bar.
  2. Select "Group by Attribute" in the left panel.
  3. Type in the name of the attribute all the areas share which you would like to remove.Click on "OK". (The attributes can be assigned in the properties panel on the right side under the tab attributes. You can choose an existing or make a new one.)
  4. The filter is added to the list and the areas with the attribute are grouped under it.
  5. Select the filter and click on "Remove".
  6. When prompted if you want to delete all children choose "yes".
