How to import data from ArcGIS Online
How to log in an ArcGIS Online account in the Tygron Client Application:
  1. Click on the Community tab and click on Sign in with ArcGIS
  2. In the new panel that pops up, choose Default ArcGIS Online and click on Continue to login
  3. Fill in your username and password
    If successful, the message "logged in with account: <your accountname>" will be displayed and the panel will be closed automatically. You are now logged in with your ArcGIS Login.
  4. To add your private or organization own data, see the how to access your data steps below.
How to import data from ArcGIS Online:
  1. Make sure your are logged in to either ArcGIS Online or ArcGIS Enterprise portal. See above for the steps.
  2. Select Current Situation in the ribbon bar
  3. Open the Geo Data Wizard and choose as what type of data your data should be imported.
  4. Choose as import method the Catalogue service.
  5. Select Catalogue service ArcGIS Online (also to access the Enterprise portal data).
  6. In step 1.2 you can browse through your Esri content, Esri organization content and Esri open data. Select the data you want to import and click Next. In step 1.3 you can choose the layer you want to import. Proceed with the wizard.
  • In Select Catalog step of the Geo Data Wizard, datasets that are listed in ArcGIS Online or in the ArcGIS Enterprise portal with an extent which is not in your project location are not visible.
  • In the Select Service step of the Geo Data Wizard, if the dataset you want to import is not in the same location as your project, the data cannot be imported.
