Version 2018.2.1
Version 2018.2.1 is released on engine.tygron.com (LTS) on Monday March 19th 2018
Geo
- New system for loading Elevation Model data from GEO sources, like the AHN. This speeds up the Wizard process and also reduces errors.
- Wizard option to select if you want to use the AHN data when creating the Elevation Model. Using the AHN creates extra detail but also a less smooth map.
Interface
- Area selection panel will react faster when using a Template.
