Select distance (TQL)
| Select | Unit | Description | Fixed clause amount | Polygon based |
| DISTANCE | decimal | Returns the distance between two items | 2 | false |
Allowed clause parameters
| Param | Type | Description | Limits search polygon |
| ADDRESS | Item ID | Address with ID | false |
| AREA | Item ID | Area with ID | true |
| BUILDING | Item ID | Building with ID | false |
| NEIGHBORHOOD | Item ID | Neighborhood with ID | true |
- The distance is measured between the center point of the first item and the center point of the second item.
