How to change properties of a Scenario
Editor → Multi Scenario (Ribbon tab) → Scenario (Ribbon bar) → The Scenario to edit (Left panel)
Scenario
By selecting a scenario entry on the left panel, the following properties become available on the right panel:
Scenarios (left panel)
Name
Scenario name and description field (right panel)
In the Name field a more suitable name can be entered, if desired. Examples of this can be: "Tutorial", "Prologue", etc.
How to change the name of a scenario:
  1. Select Multi-Scenario → Scenarios
  2. Select scenario to be renamed from the left panel
  3. Select Name field on right panel
  4. Delete the previous name
  5. Enter new name
  6. Confirm by pressing the 'Enter' key
Description
The description field allows for describing the scenario in the Editor. This is convenient when the scenario has added complexity.
How to change the description of a scenario:
  2. Select scenario to have description added from the left panel
  3. Select Description field on right panel
  4. Delete the previous text (if needed)
  5. Enter new description
  6. Text is instantly confirmed when typed ('Enter' key adds hard return to text)
